A11Y: make th keyboard accessible + aria attribs (PR #11895)
  • Make sortable th keyboard accessible with tabindex
  • Allow sortable th to be triggered by space/enter
  • Add scope, aria-role, aria-sort, aria-pressed to sortable th
GitHub
we font allow this pattern anymore. use => to keep upper scope.
can we use native js here ? Element.closest() - Référence Web API | MDN
you don’t need this anymore with fat arrow
slightly outside the scope of this PR, but I think we should stop using keyCode and use code. So not sure we should keep introducing this kind of code.
See:
why do we need an array here ?
same here why an array? Im missing something I guess.
should we support “none” when !this.isSorting ?
nah you’re not missing anything, I copied some similar code and didn’t think about it enough.
sure, added it
I tried using e.target.closest(sel) here instead and it didn’t end up working… I must be missing something?
it’s possible behavior is slightly different
I think you just use computed property and:
ariaPressed: and("sortable", "iSorting")
https://api.emberjs.com/ember/release/functions/@ember%2Fobject%2Fcomputed/and
I’m probably missing something but that didn’t work for me
figured it out
This pull request introduces 1 alert when merging 1da70676fe0330e96411e6427e9ba70b2ee0d044 into c478ffc6620cdc83c2a7e830b05b7cb7354663f3 - view on LGTM.com
new alerts:
  • 1 for Overwritten property
