This will change this link: https://github.com/discourse/discourse/commit/ee76f1926defa8309b3a7ea64a25707519529a13
into the following onebox:
Feedbacks much appreciated
You’ve signed the CLA, ZogStriP. Thank you! This pull request is ready for review.
yay … thanks !!!
— Reply to this email directly or view it on GitHubhttps://github.com/discourse/discourse/pull/629#issuecomment-15813151 .
only mild change I would possibly make is show a bit of the diff if possible with a show more button.
what about when there are several files? Should I show the diff of the first one?
I would cap it at a number of lines, say show a max of 80 lines of diff … with a more button. you need to cover the case where there are 10000 changes in one file.
— Reply to this email directly or view it on GitHubhttps://github.com/discourse/discourse/pull/629#issuecomment-15813389 .
Sure. My question should have been: is it ok to preview only the first X changes of the first file when several files are changed?
I think so, as long as a clear “show more” button is at the bottom.
— Reply to this email directly or view it on GitHubhttps://github.com/discourse/discourse/pull/629#issuecomment-15813438 .
Ok, I’ll do that tomorrow then. Going to now.
K … yanking this in for now
