Add label to enable log capturing on tests
diff --git a/spec/fixtures/container_data/basic_container.yml b/spec/fixtures/container_data/basic_container.yml
index d61ccd7..e479c82 100644
--- a/spec/fixtures/container_data/basic_container.yml
+++ b/spec/fixtures/container_data/basic_container.yml
@@ -1,6 +1,7 @@
 Config:
-  Labels: {}
+  Labels:
+    org.discourse.mobystash.enable: "true"
   Hostname: basic-container
   Image: rspec/basic_container:latest
 Image: poiuytrewqbasic
diff --git a/spec/fixtures/container_data/disabled_container.yml b/spec/fixtures/container_data/disabled_container.yml
index 30d585a..8519f96 100644
--- a/spec/fixtures/container_data/disabled_container.yml
+++ b/spec/fixtures/container_data/disabled_container.yml
@@ -1,7 +1,6 @@
 Config:
-  Labels:
-    org.discourse.mobystash.disable: "yes"
+  Labels: {}
   Hostname: disabled-container
   Image: rspec/disabled_container:latest
 Image: poiuytrewqdisabled
diff --git a/spec/fixtures/container_data/filtered_container.yml b/spec/fixtures/container_data/filtered_container.yml
index 13b7ac7..145f9ea 100644
--- a/spec/fixtures/container_data/filtered_container.yml
+++ b/spec/fixtures/container_data/filtered_container.yml
@@ -1,6 +1,7 @@
 Config:
   Labels:
     org.discourse.mobystash.filter_regex: Z
   Hostname: filtered-container
   Image: rspec/filtered_container:latest
diff --git a/spec/fixtures/container_data/syslog_container.yml b/spec/fixtures/container_data/syslog_container.yml
index 42f026b..af28281 100644
--- a/spec/fixtures/container_data/syslog_container.yml
+++ b/spec/fixtures/container_data/syslog_container.yml
@@ -1,6 +1,7 @@
 Config:
   Labels:
+    org.discourse.mobystash.enable: "yes"
     org.discourse.mobystash.parse_syslog: "yes"
   Hostname: syslog-container
   Image: rspec/syslog_container:latest
diff --git a/spec/fixtures/container_data/tagged_container.yml b/spec/fixtures/container_data/tagged_container.yml
index 4b5d7d7..aeb43a8 100644
--- a/spec/fixtures/container_data/tagged_container.yml
+++ b/spec/fixtures/container_data/tagged_container.yml
@@ -1,6 +1,7 @@
 Config:
   Labels:
     org.discourse.mobystash.tag.something: "funny"
     org.discourse.mobystash.tag.fred: "jones"
     org.discourse.mobystash.tag.nested.tags: "work"
diff --git a/spec/fixtures/container_data/tty_container.yml b/spec/fixtures/container_data/tty_container.yml
index 49d1c86..d5a241e 100644
--- a/spec/fixtures/container_data/tty_container.yml
+++ b/spec/fixtures/container_data/tty_container.yml
@@ -1,7 +1,8 @@
 Config:
   Tty: true
-  Labels: {}
+  Labels:
   Hostname: tty-container
   Image: rspec/tty_container:latest
 Image: poiuytrewqtty
GitHub sha: 5a660af09db32acd076f0b189d8f8487b5a362c2
This commit appears in #14 which was approved by saj. It was merged by chipflake.
