Add missing lines due to bad commit in 40fd876d1edb1a376a4eb592c9de4a178352a760.
diff --git a/templates/web.letsencrypt.ssl.template.yml b/templates/web.letsencrypt.ssl.template.yml
index 463f04e..4f46ccb 100644
--- a/templates/web.letsencrypt.ssl.template.yml
+++ b/templates/web.letsencrypt.ssl.template.yml
@@ -62,7 +62,7 @@ hooks:
             # Try to issue the cert again if something goes wrong
             LE_WORKING_DIR="${LETSENCRYPT_DIR}" $$ENV_LETSENCRYPT_DIR/acme.sh --issue -d $$ENV_DISCOURSE_HOSTNAME -k 4096 --force -w /var/www/discourse/public
           else
-            echo "force_https = 'true'" >> "/var/www/discourse/config/discourse.conf"
+            grep -q 'force_https' "/var/www/discourse/config/discourse.conf" || echo "force_https = 'true'" >> "/var/www/discourse/config/discourse.conf"
           fi
           LE_WORKING_DIR="${LETSENCRYPT_DIR}" $$ENV_LETSENCRYPT_DIR/acme.sh --installcert -d $$ENV_DISCOURSE_HOSTNAME --fullchainpath /shared/ssl/$$ENV_DISCOURSE_HOSTNAME.cer --keypath /shared/ssl/$$ENV_DISCOURSE_HOSTNAME.key --reloadcmd "sv reload nginx"
GitHub sha: f15044dd
