add perf
add perf
diff --git a/bench/topic_mysql_perf.rb b/bench/topic_mysql_perf.rb
new file mode 100644
index 0000000..7dad663
--- /dev/null
+++ b/bench/topic_mysql_perf.rb
@@ -0,0 +1,310 @@
+require 'bundler/inline'
+gemfile do
+  source 'https://rubygems.org'
+  gem 'mysql2'
+  gem 'mini_sql', path: '../'
+  gem 'activesupport'
+  gem 'activerecord'
+  gem 'activemodel'
+  gem 'memory_profiler'
+  gem 'benchmark-ips'
+  gem 'sequel', github: 'jeremyevans/sequel'
+end
+require 'mysql2'
+require 'sequel'
+require 'active_record'
+require 'memory_profiler'
+require 'benchmark/ips'
+require 'mini_sql'
+ActiveRecord::Base.establish_connection(
+  :adapter => "mysql2",
+  :database => "test_db",
+  :username => "root",
+  :password => ''
+DB = Sequel.connect("mysql2://root:@localhost/test_db")
+mysql = ActiveRecord::Base.connection.raw_connection
+mysql.query <<SQL
+drop table if exists topics
+SQL
+mysql.query <<~SQL
+  CREATE TABLE `topics` (
+    `id` bigint(20) NOT NULL AUTO_INCREMENT,
+    `title` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL,
+    `last_posted_at` datetime DEFAULT NULL,
+    `created_at` datetime NOT NULL,
+    `updated_at` datetime NOT NULL,
+    `views` int(11) NOT NULL DEFAULT '0',
+    `posts_count` int(11) NOT NULL DEFAULT '0',
+    `user_id` int(11) DEFAULT NULL,
+    `last_post_user_id` int(11) NOT NULL,
+    `reply_count` int(11) NOT NULL DEFAULT '0',
+    `featured_user1_id` int(11) DEFAULT NULL,
+    `featured_user2_id` int(11) DEFAULT NULL,
+    `featured_user3_id` int(11) DEFAULT NULL,
+    `avg_time` int(11) DEFAULT NULL,
+    `deleted_at` datetime DEFAULT NULL,
+    `highest_post_number` int(11) NOT NULL DEFAULT '0',
+    `image_url` varchar(255) COLLATE utf8mb4_unicode_ci DEFAULT NULL,
+    `like_count` int(11) NOT NULL DEFAULT '0',
+    `incoming_link_count` int(11) NOT NULL DEFAULT '0',
+    `category_id` int(11) DEFAULT NULL,
+    `visible` tinyint(1) NOT NULL DEFAULT '1',
+    `moderator_posts_count` int(11) NOT NULL DEFAULT '0',
+    `closed` tinyint(1) NOT NULL DEFAULT '0',
+    `archived` tinyint(1) NOT NULL DEFAULT '0',
+    `bumped_at` datetime NOT NULL,
+    `has_summary` tinyint(1) NOT NULL DEFAULT '0',
+    `archetype` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT 'regular',
+    `featured_user4_id` int(11) DEFAULT NULL,
+    `notify_moderators_count` int(11) NOT NULL DEFAULT '0',
+    `spam_count` int(11) NOT NULL DEFAULT '0',
+    `pinned_at` datetime DEFAULT NULL,
+    `score` float DEFAULT NULL,
+    `percent_rank` float NOT NULL DEFAULT '1',
+    `subtype` varchar(255) COLLATE utf8mb4_unicode_ci DEFAULT NULL,
+    `slug` varchar(255) COLLATE utf8mb4_unicode_ci DEFAULT NULL,
+    `deleted_by_id` int(11) DEFAULT NULL,
+    `participant_count` int(11) DEFAULT '1',
+    `word_count` int(11) DEFAULT NULL,
+    `excerpt` varchar(1000) COLLATE utf8mb4_unicode_ci DEFAULT NULL,
+    `pinned_globally` tinyint(1) NOT NULL DEFAULT '0',
+    `pinned_until` datetime DEFAULT NULL,
+    `fancy_title` varchar(400) COLLATE utf8mb4_unicode_ci DEFAULT NULL,
+    `highest_staff_post_number` int(11) NOT NULL DEFAULT '0',
+    `featured_link` varchar(255) COLLATE utf8mb4_unicode_ci DEFAULT NULL,
+    `reviewable_score` float NOT NULL DEFAULT '0',
+    PRIMARY KEY (`id`)
+SQL
+class Topic < ActiveRecord::Base
+end
+class TopicSequel < Sequel::Model(:topics)
+end
+Topic.transaction do
+  topic = {
+  Topic.columns.each do |c|
+    topic[c.name.to_sym] = case c.type
+                           when :integer then 1
+                           when :datetime then Time.now
+                           when :boolean then false
+                           when :float then 1.0
+                           else "HELLO WORLD" * 2
+                           end
+  end
+  1000.times do |id|
+    topic[:id] = id
+    Topic.create!(topic)
+  end
+end
+$conn = ActiveRecord::Base.connection.raw_connection
+def ar_title_id_pluck
+  s = +""
+  Topic.limit(1000).order(:id).pluck(:id, :title).each do |id, title|
+    s << id.to_s
+    s << title
+  end
+  s
+end
+def ar_title_id
+  s = +""
+  Topic.limit(1000).order(:id).select(:id, :title).each do |t|
+    s << t.id.to_s
+    s << t.title
+  end
+  s
+end
+def mysql_title_id
+  s = +""
+  # use the safe pattern here
+  r = $conn.query(-"select id, title from topics order by id limit 1000", as: :array)
+  r.each do |row|
+    s << row[0].to_s
+    s << row[1]
+  end
+  s
+end
+$mini_sql = MiniSql::Connection.get($conn)
+def mini_sql_title_id
+  s = +""
+  $mini_sql.query(-"select id, title from topics order by id limit 1000").each do |t|
+    s << t.id.to_s
+    s << t.title
+  end
+  s
+end
+def sequel_select_title_id
+  s = +""
+  TopicSequel.limit(1000).order(:id).select(:id, :title).each do |t|
+    s << t.id.to_s
+    s << t.title
+  end
+  s
+end
+def sequel_pluck_title_id
+  s = +""
+  TopicSequel.limit(1000).order(:id).select_map([:id, :title]).each do |t|
+    s << t[0].to_s
+    s << t[1]
+  end
+  s
+end
+# usage is not really recommended but just to compare to pluck lets have it
+def mini_sql_title_id_query_single
+  s = +""
+  i = 0
+  r = $mini_sql.query_single(-"select id, title from topics order by id limit 1000")
+  while i < r.length
+    s << r[i].to_s
+    s << r[i+1]
+    i += 2
+  end
+  s
+end
+results = [
+  ar_title_id,
+  ar_title_id_pluck,
+  mysql_title_id,
+  mini_sql_title_id,
+  sequel_pluck_title_id,
+  sequel_select_title_id,
+  mini_sql_title_id_query_single
+exit(-1) unless results.uniq.length == 1
+Benchmark.ips do |r|
+  r.report("ar select title id") do |n|
+    while n > 0
+      ar_title_id
+      n -= 1
+    end
+  end
+  r.report("ar select title id pluck") do |n|
+    while n > 0
+      ar_title_id_pluck
+      n -= 1
+    end
+  end
+  r.report("sequel title id select") do |n|
+    while n > 0
+      n -= 1
+    end
+  end
+  r.report("mysql select title id") do |n|
+    while n > 0
+      mysql_title_id
+      n -= 1
+    end
+  end
+  r.report("mini_sql select title id") do |n|
+    while n > 0
+      mini_sql_title_id
+      n -= 1
+    end
+  end
+  r.report("sequel title id pluck") do |n|
+    while n > 0
+      n -= 1
+    end
+  end
+  r.report("mini_sql query_single title id") do |n|
+    while n > 0
+      n -= 1
+    end
+  end
+  r.compare!
+end
+def wide_topic_ar
+  Topic.first
+end
+def wide_topic_mysql
+  r = $conn.query("select * from topics limit 1", as: :hash)
+  row = r.first
+  row
+end
+def wide_topic_sequel
+  TopicSequel.first
+end
+def wide_topic_mini_sql
+  $conn.query("select * from topics limit 1").first
+end
+  r.report("wide topic ar") do |n|
+    while n > 0
+      wide_topic_ar
+      n -= 1
+    end
+  end
+  r.report("wide topic sequel") do |n|
+    while n > 0
+      wide_topic_sequel
+      n -= 1
+    end
+  end
+  r.report("wide topic mysql") do |n|
+    while n > 0
+      wide_topic_mysql
+      n -= 1
+    end
+  end
+  r.report("wide topic mini sql") do |n|
+    while n > 0
+      wide_topic_mini_sql
+      n -= 1
+    end
+  end
+  r.compare!
+end
+# Comparison:
+# mysql select title id:      486.5 i/s
+# mini_sql query_single title id:      450.3 i/s - same-ish: difference falls within error
+# sequel title id pluck:      367.9 i/s - 1.32x  slower
+# sequel title id select:      352.5 i/s - 1.38x  slower
+# mini_sql select title id:      346.2 i/s - 1.41x  slower
+# ar select title id pluck:      320.5 i/s - 1.52x  slower
+#   ar select title id:      102.8 i/s - 4.73x  slower
+# Comparison:
+#  wide topic mini sql:     7837.2 i/s
+#     wide topic mysql:     7085.7 i/s - same-ish: difference falls within error
+#    wide topic sequel:     5168.7 i/s - 1.52x  slower
+#        wide topic ar:     2631.7 i/s - 2.98x  slower
diff --git a/bench/topic_perf.rb b/bench/topic_perf.rb
index 6482623..cc7c93b 100644
GitHub sha: e9e198d3
