Add plugin spec
Add plugin spec
Adds plugin specs to test triggers
diff --git a/spec/plugin_spec.rb b/spec/plugin_spec.rb
new file mode 100644
index 0000000..ab00a19
--- /dev/null
+++ b/spec/plugin_spec.rb
@@ -0,0 +1,27 @@
+require 'rails_helper'
+describe "plugin" do
+  before do
+    SiteSetting.akismet_api_key = 'not_a_real_key'
+    SiteSetting.akismet_enabled = true
+  end
+  it "queues posts on post for trust level 1" do
+    user = Fabricate(:user, trust_level: TrustLevel[1])
+    pc = PostCreator.new(user, raw: 'this is the new content for my topic', title: 'this is my new topic title')
+    post = pc.create
+    expect(DiscourseAkismet::PostsBouncer.to_check.length).to eq(1)
+    expect(Jobs::CheckAkismetPost.jobs.length).to eq(0)
+  end
+  it "immediately queues posts on post for trust level 0" do
+    user = Fabricate(:user, trust_level: TrustLevel[0])
+    post = pc.create
+    expect(Jobs::CheckAkismetPost.jobs.length).to eq(1)
+  end
+end
GitHub sha: c6e4a556
