Added initial topic queries
diff --git a/README.md b/README.md
new file mode 100644
index 0000000..795d7cd
--- /dev/null
+++ b/README.md
@@ -0,0 +1,3 @@
+# Discourse URL Filters
+Be able to filter topic lists with url params.
diff --git a/config/settings.yml b/config/settings.yml
index 0000000..b0ac71a
--- /dev/null
+++ b/config/settings.yml
@@ -0,0 +1,4 @@
+plugins:
+  url_filters_enabled:
+    default: true
+    client: false
index 0000000..922e9fd
--- /dev/null
+++ b/plugin.rb
@@ -0,0 +1,123 @@
+# name: discourse-url-filters
+# about: Adds url query params for filtering topics
+# version: 0.1
+# authors: Blake Erickson
+# url: https://github.com/discourse/discourse-url-filters
+enabled_site_setting :url_filters_enabled
+PLUGIN_NAME = "discourse_url_filters".freeze
+after_initialize do
+  if Discourse.has_needed_version?(Discourse::VERSION::STRING, '1.8.0.beta6')
+    require_dependency 'topic_query'
+    # After
+    TopicQuery.add_custom_filter(:after) do |results, topic_query|
+      if after = topic_query.options[:after]
+        if (after = after.to_i) > 0
+          results = results.where('topics.created_at > ?', after.days.ago)
+        end
+      end
+      results
+    end
+    # Categories
+    TopicQuery.add_custom_filter(:categories) do |results, topic_query|
+      if categories_param = topic_query.options[:categories]
+        categories = categories_param.split(',')
+        category_ids = Category.where(slug: categories).pluck(:id)
+        #results = results.where('topics.category_id = ?', category_ids)
+        puts "CATEGORIES: #{category_ids}"
+        results = results.where(<<~SQL, category_ids: category_ids)
+        topics.category_id IN (:category_ids)
+        SQL
+      end
+      results
+    end
+    # Include Tags
+    # Using include_tags for now until we figure out why there are issues using
+    # the existing tags query param
+    TopicQuery.add_custom_filter(:include_tags) do |results, topic_query|
+      if tags_param = topic_query.options[:include_tags]
+        tags = tags_param.split(',')
+        tag_ids = Tag.where(name: tags).pluck(:id)
+        puts "TAGS: #{tag_ids}"
+        results = results.where(<<~SQL, tag_ids: tag_ids)
+        topics.id IN (
+          SELECT topic_tags.topic_id
+          FROM topic_tags
+          INNER JOIN tags ON tags.id = topic_tags.tag_id
+          WHERE tags.id IN (:tag_ids)
+        SQL
+      end
+      results
+    end
+    # Topic Author
+    # Filter by topics where the user is a member of the specified group
+    TopicQuery.add_custom_filter(:topic_author) do |results, topic_query|
+      if topic_author_param = topic_query.options[:topic_author]
+        group = Group.find_by(name: topic_author_param)
+        if group
+          results = results.where(<<~SQL, group_id: group.id)
+          topics.id IN (
+            SELECT posts.topic_id
+            FROM posts
+            INNER JOIN group_users gu ON gu.user_id = posts.user_id
+            WHERE gu.group_id = :group_id
+            AND posts.post_number = 1
+          SQL
+        end
+      end
+      results
+    end
+    # Has Reply From
+    TopicQuery.add_custom_filter(:reply_from) do |results, topic_query|
+      if reply_from_param = topic_query.options[:reply_from]
+        group = Group.find_by(name: reply_from_param)
+        if group
+          topics.id IN (
+            FROM posts
+            AND posts.post_number > 1
+          SQL
+        end
+      end
+      results
+    end
+    # No Reply From
+    TopicQuery.add_custom_filter(:no_reply_from) do |results, topic_query|
+      if no_reply_from_param = topic_query.options[:no_reply_from]
+        group = Group.find_by(name: no_reply_from_param)
+        if group
+          topics.id NOT IN (
+            FROM posts
+          SQL
+        end
+      end
+      results
+    end
+  end
+end
GitHub sha: a8b33b64874529473a5e0e72588466d3af6be9df
