Added JSHint support for travis builds (PR #212)
Added .jshintrc to the project (configuration file)
added the JShint command to the after script so that it doesnt fail the build at the present moment, if you move it to the before script it will fail the build
after_script:
  • jshint .
Before script build https://travis-ci.org/billybonks/discourse/builds/4938503
GitHub
That’s a lot of commits… You should squashed them into a single commit (cf. https://github.com/discourse/discourse/blob/master/docs/CONTRIBUTING.md#pro-tip)
ya thought that would be a problem lol :/… ill fix the Multitude of commits after work
This might not be necessary anymore. We’ve converted our coffeescript to javascript and added support for rake jshint - can this patch be updated so that travis calls that command?
Also could you sign our CLA please? http://www.discourse.org/cla - thanks!
Closing this pull and reopening with clean commits
