Allows mod posts to be created for category group moderators on closed/archived topics (#10399)
diff --git a/lib/guardian/topic_guardian.rb b/lib/guardian/topic_guardian.rb
index 1cd93e4..263163b 100644
--- a/lib/guardian/topic_guardian.rb
+++ b/lib/guardian/topic_guardian.rb
@@ -65,7 +65,7 @@ module TopicGuardian
     return false if topic.trashed?
     return true if is_admin?
-    trusted = (authenticated? && user.has_trust_level?(TrustLevel[4])) || is_moderator?
+    trusted = (authenticated? && user.has_trust_level?(TrustLevel[4])) || is_moderator? || can_perform_action_available_to_group_moderators?(topic)
     (!(topic.closed? || topic.archived?) || trusted) && can_create_post?(topic)
diff --git a/spec/requests/topics_controller_spec.rb b/spec/requests/topics_controller_spec.rb
index 3f59df4..6b93acb 100644
--- a/spec/requests/topics_controller_spec.rb
+++ b/spec/requests/topics_controller_spec.rb
@@ -879,15 +879,45 @@ RSpec.describe TopicsController do
         expect(response.status).to eq(200)
         expect(topic.reload.closed).to eq(true)
+        expect(topic.posts.last.action_code).to eq('closed.enabled')
+      end
+      it 'should allow a group moderator to open a closed topic' do
+        topic.update!(closed: true)
+        expect do
+          put "/t/#{topic.id}/status.json", params: {
+            status: 'closed', enabled: 'false'
+        end.to change { topic.reload.posts.count }.by(1)
+        expect(response.status).to eq(200)
+        expect(topic.reload.closed).to eq(false)
+        expect(topic.posts.last.action_code).to eq('closed.disabled')
       it 'should allow a group moderator to archive a topic' do
+        expect do
+            status: 'archived', enabled: 'true'
+        expect(topic.reload.archived).to eq(true)
+        expect(topic.posts.last.action_code).to eq('archived.enabled')
+      end
+      it 'should allow a group moderator to unarchive an archived topic' do
+        topic.update!(archived: true)
-          status: 'archived', enabled: 'true'
+          status: 'archived', enabled: 'false'
-        expect(topic.reload.archived).to eq(true)
+        expect(topic.reload.archived).to eq(false)
+        expect(topic.posts.last.action_code).to eq('archived.disabled')
       it 'should not allow a group moderator to pin a topic' do
GitHub sha: d67f7a79
This commit appears in #10399 which was approved by eviltrout. It was merged by jbrw.
