Auto assign on followup, auto unassign on approve
I nice little workflow change would be
  • IF discourse assign is installed
  • AND code_review_auto_assign_on_followup is enabled (default true)
  • AND OP is staff
  • THEN auto assign the the topic when you click followup
Similarly:
  • AND code_review_auto_unassign_on_approve is enabled (default true)
  • AND item is assigned
  • THEN auto unassign the the topic when you click approve
Thoughts, fears?
@nbianca can you add that to your list? No rush though.
This is done.:heavy_check_mark:
