Better handling of images
When syncing to github we should rewrite the upload:// URLs. Here’s an example: Extra margin isn't needed on mobile · discourse/discourse@a113777 · GitHub
Here’s what it shows
(was literally writing the same report :wink:)
I fixed it manually for now, which also makes me think we should set some default dimensions as well :wink:
Quotes are also a problem, one way of fixing this is doing markdown->html->markdown prior to sync, thoughts?
