Build(deps): Bump aws-eventstream from 1.0.3 to 1.1.0 (PR #9395)
Bumps aws-eventstream from 1.0.3 to 1.1.0.
Changelog
Sourced from aws-eventstream's changelog.
1.1.0 (2020-04-08)
  • Feature - Remove internal ByteBuffer and replace with String to remove dup and string mutation.
Commits
GitHub
