Build(deps): Bump aws-eventstream from 1.1.1 to 1.2.0 (PR #14215)
Bumps aws-eventstream from 1.1.1 to 1.2.0.
Changelog
Sourced from aws-eventstream's changelog.
1.2.0 (2021-09-01)
  • Feature - AWS SDK for Ruby no longer supports Ruby runtime versions 1.9, 2.0, 2.1, and 2.2.
Commits
GitHub
