Build(deps): Bump aws-partitions from 1.294.0 to 1.295.0 (PR #9367)
Bumps aws-partitions from 1.294.0 to 1.295.0.
Changelog
Sourced from aws-partitions's changelog.
1.295.0 (2020-04-06)
  • Feature - Updated the partitions source data the determines the AWS service regions and endpoints.
Commits
GitHub
OK, I won’t notify you about version 1.x.x again, unless you re-open this PR or update to a 1.x.x release yourself.
