Build(deps): Bump aws-partitions from 1.329.0 to 1.330.0 (PR #10071)
Bumps aws-partitions from 1.329.0 to 1.330.0.
Changelog
Sourced from aws-partitions's changelog.
1.330.0 (2020-06-17)
  • Feature - Updated the partitions source data the determines the AWS service regions and endpoints.
Commits
GitHub
Superseded by #10086.
