Build(deps): Bump aws-partitions from 1.329.0 to 1.331.0 (PR #10086)
Bumps aws-partitions from 1.329.0 to 1.331.0.
Changelog
Sourced from aws-partitions's changelog.
1.331.0 (2020-06-18)
  • Feature - Updated the partitions source data the determines the AWS service regions and endpoints.
1.330.0 (2020-06-17)
Commits
GitHub
OK, I won’t notify you about version 1.x.x again, unless you re-open this PR or update to a 1.x.x release yourself.
