Build(deps): Bump aws-sdk-core from 3.91.0 to 3.91.1 (PR #9219)
Bumps aws-sdk-core from 3.91.0 to 3.91.1.
Changelog
Sourced from aws-sdk-core's changelog.
3.91.1 (2020-03-10)
  • Issue - Rescue from JSON::ParserError when using Oj.mimic_JSON. (#2247)
Commits
GitHub
A newer version of aws-sdk-core exists, but since this PR has been edited by someone other than Dependabot I haven’t updated it. You’ll get a PR for the updated version as normal once this PR is merged.
@dependabot rebase
Looks like this PR has been edited by someone other than Dependabot. That means Dependabot can’t rebase it - sorry!
If you’re happy for Dependabot to recreate it from scratch, overwriting any edits, you can request @dependabot recreate.
Superseded by #9325.
