Build(deps): Bump aws-sdk-core from 3.94.0 to 3.94.1 (PR #9631)
Bumps aws-sdk-core from 3.94.0 to 3.94.1.
Changelog
Sourced from aws-sdk-core's changelog.
3.94.1 (2020-05-04)
  • Issue - When handling errors in XML responses, don't set a new error on the response if one is already set.
Commits
GitHub
OK, I won’t notify you about version 3.x.x again, unless you re-open this PR or update to a 3.x.x release yourself.
