Build(deps): Bump aws-sdk-core from 3.96.1 to 3.97.1 (PR #9959)
Bumps aws-sdk-core from 3.96.1 to 3.97.1.
Changelog
Sourced from aws-sdk-core's changelog.
3.97.1 (2020-06-01)
  • Issue - Convert ENV['AWS_MAX_ATTEMPTS'] String value to Integer when set. (#2319)
  • Issue - Handle unknown and unmodeled events from event streams by ignoring them and providing a new callback rather than raising an error.
3.97.0 (2020-05-28)
  • Feature - Default endpoint_discovery to true for services with at least one operation that requires it.
  • Feature - Updated Aws::STS::Client with the latest API changes.
Commits
GitHub
OK, I won’t notify you about version 3.x.x again, unless you re-open this PR or update to a 3.x.x release yourself.
