Build(deps): Bump aws-sdk-core from 3.99.1 to 3.100.0 (PR #10056)
Bumps aws-sdk-core from 3.99.1 to 3.100.0.
Changelog
Sourced from aws-sdk-core's changelog.
3.100.0 (2020-06-15)
  • Feature - Updated the list of parameters to filter when logging.
3.99.2 (2020-06-12)
  • Issue - Don't retry streaming requests with blocks (#2311)
Commits
GitHub
OK, I won’t notify you about version 3.x.x again, unless you re-open this PR or update to a 3.x.x release yourself.
