Build(deps): Bump aws-sdk-kms from 1.30.0 to 1.31.0 (PR #9693)
Bumps aws-sdk-kms from 1.30.0 to 1.31.0.
Changelog
Sourced from aws-sdk-kms's changelog.
1.31.0 (2020-05-07)
  • Feature - Code Generated Changes, see ./build_tools or aws-sdk-core's CHANGELOG.md for details.
Commits
GitHub
OK, I won’t notify you about version 1.x.x again, unless you re-open this PR or update to a 1.x.x release yourself.
