Build(deps): Bump aws-sdk-s3 from 1.62.0 to 1.63.0 (PR #9523)
Bumps aws-sdk-s3 from 1.62.0 to 1.63.0.
Changelog
Sourced from aws-sdk-s3's changelog.
1.63.0 (2020-04-22)
  • Feature - Add presigned_request method to the Presigner class. This method returns a URL and headers necessary rather than hoisting them onto the query string.
  • Feature - Force HTTPS when using virtual_host: true on the Presigner class.
Commits
GitHub
OK, I won’t notify you about version 1.x.x again, unless you re-open this PR or update to a 1.x.x release yourself.
