Build(deps): Bump aws-sdk-s3 from 1.66.0 to 1.67.0 (PR #9916)
Bumps aws-sdk-s3 from 1.66.0 to 1.67.0.
Changelog
Sourced from aws-sdk-s3's changelog.
1.67.0 (2020-05-28)
  • Feature - Code Generated Changes, see ./build_tools or aws-sdk-core's CHANGELOG.md for details.
Commits
GitHub
OK, I won’t notify you about version 1.x.x again, unless you re-open this PR or update to a 1.x.x release yourself.
