Build(deps): Bump aws-sdk-sns from 1.23.0 to 1.24.0 (PR #9914)
Bumps aws-sdk-sns from 1.23.0 to 1.24.0.
Changelog
Sourced from aws-sdk-sns's changelog.
1.24.0 (2020-05-28)
  • Feature - Code Generated Changes, see ./build_tools or aws-sdk-core's CHANGELOG.md for details.
Commits
GitHub
Superseded by #10022.
