Build(deps): Bump aws-sdk-sns from 1.23.0 to 1.25.0 (PR #10022)
Bumps aws-sdk-sns from 1.23.0 to 1.25.0.
Changelog
Sourced from aws-sdk-sns's changelog.
1.25.0 (2020-06-10)
  • Feature - Code Generated Changes, see ./build_tools or aws-sdk-core's CHANGELOG.md for details.
1.24.0 (2020-05-28)
Commits
GitHub
Superseded by #10033.
