Build(deps): Bump aws-sigv4 from 1.1.2 to 1.1.3 (PR #9560)
Bumps aws-sigv4 from 1.1.2 to 1.1.3.
Changelog
Sourced from aws-sigv4's changelog.
1.1.3 (2020-04-27)
  • Issue - Don't rely on the set? method of credentials.
Commits
GitHub
