Build(deps): Bump aws-sigv4 from 1.1.3 to 1.1.4 (PR #9913)
Bumps aws-sigv4 from 1.1.3 to 1.1.4.
Changelog
Sourced from aws-sigv4's changelog.
1.1.4 (2020-05-28)
  • Issue - Don't use expect header to compute Signature.
Commits
GitHub
Looks like aws-sigv4 is up-to-date now, so this is no longer needed.
