Build(deps): Bump aws-sigv4 from 1.1.4 to 1.2.0 (PR #10070)
Bumps aws-sigv4 from 1.1.4 to 1.2.0.
Changelog
Sourced from aws-sigv4's changelog.
1.2.0 (2020-06-17)
  • Feature - Bump aws-eventstream dependency to ~> 1.
Commits
GitHub
