Build(deps): Bump aws-sigv4 from 1.2.0 to 1.2.1 (PR #10120)
Bumps aws-sigv4 from 1.2.0 to 1.2.1.
Changelog
Sourced from aws-sigv4's changelog.
1.2.1 (2020-06-24)
  • Issue - Don't overwrite host header in sigv4 signer if given.
Commits
GitHub
OK, I won’t notify you about version 1.x.x again, unless you re-open this PR or update to a 1.x.x release yourself.
