Build(deps): Bump bootsnap from 1.4.6 to 1.4.7 (PR #10293)
Bumps bootsnap from 1.4.6 to 1.4.7.
Changelog
Sourced from bootsnap's changelog.
1.4.7
  • Various performance enhancements
  • Fix race condition in heavy concurrent load scenarios that would cause bootsnap to raise
Commits
  • 530fdb1 Bump version to 1.4.7
  • 993f454 Merge pull request #309 from abicky/fix-vulnerability-of-atomic_write_cache_file
  • cd507c3 Handle non-existent load path entries
  • 56c6137 Merge pull request #312 from Shopify/path-scanner-refactor
  • 535e556 Refactor PathScanner to avoid Dir.glob
  • fc3acd5 Merge pull request #311 from Shopify/file-allocs
  • 68faeab Merge pull request #310 from Shopify/ruby-2.7
  • 17ad3cf Reduce allocations by freezing paths
  • 2cc49bb Update CI to test Ruby 2.7
  • cfd28c3 Ensure that temporary file is used only by one process
  • Additional commits viewable in compare view
GitHub
