Build(deps): Bump bootsnap from 1.4.7 to 1.4.8 (PR #10414)
Bumps bootsnap from 1.4.7 to 1.4.8.
Changelog
Sourced from bootsnap's changelog.
1.4.8
Commits
  • e8aad0c bump version to 1.4.8
  • b1096d1 Merge pull request #314 from aaronjensen/fix-error-cause-pollution
  • d7f33a6 Merge pull request #315 from t-richards/chore/gem-size
  • 280ff11 Remove unnecessary files from gem
  • 29b77ee Prevent Bootsnap::LoadPathCache::FallbackScan from polluting exception cause
  • See full diff in compare view
GitHub
