Build(deps): Bump bootsnap from 1.7.3 to 1.7.4 (PR #12793)
Bumps bootsnap from 1.7.3 to 1.7.4.
Changelog
Sourced from bootsnap's changelog.
1.7.4
  • Stop raising errors when encoutering various file system errors. The cache is now best effort, if somehow it can't be saved, bootsnapp will gracefully fallback to the original operation (e.g. Kernel.require). (#353, #177, #262)
Commits
GitHub
