Build(deps): Bump bootsnap from 1.7.4 to 1.7.5 (PR #12944)
Bumps bootsnap from 1.7.4 to 1.7.5.
Changelog
Sourced from bootsnap's changelog.
1.7.5
  • Handle a regression of Ruby 2.7.3 causing Bootsnap to call the deprecated untaint method. (#360)
  • Gracefully handle read-only file system as well as other errors preventing to persist the load path cache. (#358)
Commits
  • 22b81ae Release 1.7.5
  • 11fa130 Make sure not to call untaint on Ruby 2.7+
  • 2d40bd3 Merge pull request #358 from metaskills/ReadOnlyFilesystem
  • 4ccccfc Use SystemCallError vs Errno::EROFS
  • 4d1a410 Ignore Read-Only Filesystems
  • a7b3628 Add a GitHub issue template to help contributors confirm their issue is with ...
  • c834dff Update rake-compiler
  • fa80667 Handle bootsnap being disabled in BOOTSNAP_LOG
  • See full diff in compare view
GitHub
