Build(deps): Bump bootsnap from 1.7.5 to 1.7.6 (PR #13850)
Bumps bootsnap from 1.7.5 to 1.7.6.
Changelog
Sourced from bootsnap's changelog.
Unreleased
  • Fix reliance on set to be required.
  • Fix Encoding::UndefinedConversionError error for Rails applications when precompiling cache. (#364)
Commits
GitHub
