Build(deps): Bump bootsnap from 1.7.6 to 1.7.7 (PR #13921)
Bumps bootsnap from 1.7.6 to 1.7.7.
Changelog
Sourced from bootsnap's changelog.
1.7.7
  • Fix require_relative in evaled code on latest ruby 3.1.0-dev. (#366)
Commits
  • 1735f4d Release 1.7.7
  • b6f0c03 Merge pull request #366 from Shopify/fix-ruby-head-require-relative-from-eval...
  • 0d64e7e Handle Ruby 3.1 eval location change
  • 9562e21 Merge pull request #365 from Shopify/fix-changelog
  • 50ab282 Correct CHANGELOG.md entry for 1.7.6
  • See full diff in compare view
GitHub
