Build(deps): Bump bootsnap from 1.7.7 to 1.8.0 (PR #14171)
Bumps bootsnap from 1.7.7 to 1.8.0.
Changelog
Sourced from bootsnap's changelog.
1.8.0
  • Improve support for Pysch 4. (#368)
Commits
  • 4f65261 Release 1.8.0
  • f7bacf0 Merge pull request #368 from Shopify/yaml-unsafe-load-file
  • 1d14e25 Fix Psych 4 compatibility and add caching for YAML.unsafe_load_file
  • See full diff in compare view
GitHub
