Build(deps): Bump bootsnap from 1.8.0 to 1.8.1 (PR #14186)
Bumps bootsnap from 1.8.0 to 1.8.1.
Changelog
Sourced from bootsnap's changelog.
1.8.1
  • Fixed support for older Psych. (#369)
Commits
GitHub
