Build(deps): Bump chart.js from 2.9.3 to 2.9.4 (PR #13036)
Bumps chart.js from 2.9.3 to 2.9.4.
Release notes
Sourced from chart.js's releases.
v2.9.4
This is the last release of v2 and focused on fixing bugs identified in the v2.9.3 release.
Bugs Fixed
  • #7404 - Preserve prototypes when cloning. Thanks @​iddings
  • #7587 - Fix docs for external moment.js. Thanks @​mojoaxel
  • #7853 - Fix box recursion when dimensions are NaN. Thanks @​alessandroasm
  • #7883 - Fix call stack exception when computing label sizes. Thanks @​silentmatt
  • #7918 - Prevent global prototype pollution via the merge helper
  • #7920 - Use Object.create(null) as merge target, to prevent prototype pollution
Commits
  • @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself) You can disable automated security fix PRs for this repo from the Security Alerts page.
GitHub
This one is handled manually.
OK, I won’t notify you again about this release, but will get in touch when a new version is available.
If you change your mind, just re-open this PR and I’ll resolve any conflicts on it.
