Build(deps): Bump concurrent-ruby from 1.1.6 to 1.1.7 (PR #10402)
Bumps concurrent-ruby from 1.1.6 to 1.1.7.
Changelog
Sourced from concurrent-ruby's changelog.
Release v1.1.7 (6 August 2020)
concurrent-ruby:
  • (#879) Consider falsy value on Concurrent::Map#compute_if_absent for fast non-blocking path
  • (#876) Reset Async queue on forking, makes Async fork-safe
  • (#856) Avoid running problematic code in RubyThreadLocalVar on MRI that occasionally results in segfault
  • (#853) Introduce ThreadPoolExecutor without a Queue
Commits
  • c1114a0 Update rake-compiler-dock to add 2.7 build
  • 6da166a Add 1.1.7 documentation
  • 6b803f2 Bump version, update doc
  • 6fd8da7 Merge pull request #879 from mtsmfm/consider-falsy-in-compute-if-absent
  • e3ceb30 Consider falsy value on Concurrent::Map#compute_if_absent fast non-blocking...
  • d9efb08 Merge pull request #878 from markiz/ma/issue-863
  • 7626ed5 Merge pull request #877 from mikrobi/patch-1
  • 8841a89 Remove outdated documentation about constructor redefinition when including C...
  • 6a79be0 Update future.md
  • cd59563 Update doc
  • Additional commits viewable in compare view
GitHub
