Build(deps): Bump connection_pool from 2.2.4 to 2.2.5 (PR #12710)
Bumps connection_pool from 2.2.4 to 2.2.5.
Changelog
Sourced from connection_pool's changelog.
2.2.5
  • Fix argument forwarding on Ruby 2.7 #149
Commits
GitHub
