Build(deps): Bump cose from 0.11.0 to 1.0.0 (PR #9307)
Bumps cose from 0.11.0 to 1.0.0.
Changelog
Sourced from cose's changelog.
[v1.0.0] - 2020-03-29
Added
  • Signature verification validates key alg is compatible with the signature algorithm
NOTE: No breaking changes. Moving out of v0.x to express the intention to keep the public API stable.
Commits
  • f556cf9 Bump gem version to v1.0.0
  • 047e1ae refactor: update openssl-signature_algorithm to v0.4
  • e594e91 build: update rubocop to v0.80
  • 98f6697 test: easily spot test flakiness
  • 6c147cc feat: validate key alg is compatible with signature algorithm
  • dca9020 docs: avoid orange color for gem badge
  • See full diff in compare view
GitHub
