Build(deps): Bump cose from 1.0.0 to 1.1.0 (PR #10203)
Bumps cose from 1.0.0 to 1.1.0.
Changelog
Sourced from cose's changelog.
Changelog
Commits
  • 2384824 Bump gem version to v1.1.0
  • 4720e40 refactor: update openssl-signature_algorithm to v1
  • b6c2593 test: update cose-wg-examples
  • 7bb7158 Merge pull request #56 from bdewater/compact-hash
  • 5cd153d refactor: use Hash#compact instead of rejecting nil values
  • 53813fc ci: test against openssl gem v2.2
  • a0ae977 Merge pull request #54 from bdewater/setup-submodule
  • 7d3157c Init git submodule
  • 99b9ca3 ci: update rubies
  • eb1785f doc: fix CHANGELOG typo
  • See full diff in compare view
GitHub
