Build(deps): Bump cose from 1.1.0 to 1.2.0 (PR #10223)
Bumps cose from 1.1.0 to 1.2.0.
Changelog
Sourced from cose's changelog.
[v1.2.0] - 2020-07-10
Added
  • Support ES256K signature algorithm
Commits
GitHub
