Build(deps): Bump crack from 0.4.3 to 0.4.4 (PR #10696)
Bumps crack from 0.4.3 to 0.4.4.
Changelog
Sourced from crack's changelog.
== 0.4.4 2020-09-17
  • 1 minor patch
    • Remove safe_yaml
== 0.1.7 2010-02-19
== 0.1.3 2009-06-22
  • 1 minor patch
    • Parsing a text node with attributes stores them in the attributes method (tamalw)
== 0.1.2 2009-04-21
  • 2 minor patches
    • Correct unnormalization of attribute values (der-flo)
    • Fix error in parsing YAML in the case where a hash value ends with backslashes, and there are subsequent values in the hash (deadprogrammer)
== 0.1.1 2009-03-31
  • 1 minor patch
    • Parsing empty or blank xml now returns empty hash instead of raising error.
== 0.1.0 2009-03-28
  • Initial release.
Commits
  • 288371d Bump version to 0.4.4; update history
  • 4ecf9cf Merge pull request #59 from bf4/master
  • 1183581 Merge pull request #61 from greysteil/dont-bundle-tests
  • 261962a Exclude tests (and fixtures) from bundled gem
  • a7189fe remove safe_yaml
  • See full diff in compare view
GitHub
