Build(deps): Bump diff-lcs from 1.4.1 to 1.4.2 (PR #10117)
Bumps diff-lcs from 1.4.1 to 1.4.2.
Changelog
Sourced from diff-lcs's changelog.
1.4.2 / 2020-06-23
  • Camille Drapier fixed a small issue with RuboCop configuration. #59[]
  • Applied another fix (and unit test) to fix an issue for the Chef team. #60[], #61[]
Commits
  • 20ea8f2 Merge pull request #61 from halostatue/fix-issue-60
  • caeca62 Fix filename substitution
  • c032222 Test fix for timestamp issue
  • 9aabe2f Change when max_diff_size is applied
  • ce0190b Merge pull request #59 from CamilleDrapier/camille/fix_rubocop_typo
  • c5052cd Fix typo for rubocop cop namspace
  • See full diff in compare view
GitHub
Superseded by #10145.
