Build(deps): Bump diff-lcs from 1.4.1 to 1.4.3 (PR #10145)
Bumps diff-lcs from 1.4.1 to 1.4.3.
Changelog
Sourced from diff-lcs's changelog.
1.4.3 / 2020-06-29
  • Fixed several issues with the 1.4 on Rubies older than 2.0. Some of this was providing useful shim functions to Hoe 3.x (which dropped these older Rubies a while ago). Specifically:
    • Removed Array#lazy from a method in Diff::LCS::Hunk.
    • Changed some unit tests to use old-style Symbol-keyed hashes.
    • Changed some unit test helper functions to no longer use keyword parameters, but only a trailing options hash.
    • Made the use of psych dependent on RUBY_VERSION >= 1.9.
    Resolves #63[].
1.4.2 / 2020-06-23
  • Camille Drapier fixed a small issue with RuboCop configuration. #59[]
  • Applied another fix (and unit test) to fix an issue for the Chef team. #60[], #61[]
Commits
  • 99f65fd Release v1.4.3
  • 83bfe1b Merge pull request #64 from halostatue/fix-ruby-1.8-support
  • 2a9a662 Fix some issues with 1.4 on older Rubies
  • 20ea8f2 Merge pull request #61 from halostatue/fix-issue-60
  • caeca62 Fix filename substitution
  • c032222 Test fix for timestamp issue
  • 9aabe2f Change when max_diff_size is applied
  • ce0190b Merge pull request #59 from CamilleDrapier/camille/fix_rubocop_typo
  • c5052cd Fix typo for rubocop cop namspace
  • See full diff in compare view
GitHub
