Build(deps): Bump discourse-ember-source from 3.12.2.1 to 3.12.2.2 (PR #10251)
Bumps discourse-ember-source from 3.12.2.1 to 3.12.2.2.
Commits
GitHub
Looks like discourse-ember-source is up-to-date now, so this is no longer needed.
