Build(deps): Bump discourse-fonts from 0.0.2 to 0.0.3 (PR #10582)
Bumps discourse-fonts from 0.0.2 to 0.0.3.
Commits
GitHub
@nbianca I’ll leave this for you to merge? :slight_smile:
It’s being taken care of in #10583.
OK, I won’t notify you again about this release, but will get in touch when a new version is available. If you’d rather skip all updates until the next major or minor version, let me know by commenting @dependabot ignore this major version or @dependabot ignore this minor version.
If you change your mind, just re-open this PR and I’ll resolve any conflicts on it.
