Build(deps): Bump discourse-fonts from 0.0.3 to 0.0.4 (PR #10746)
Bumps discourse-fonts from 0.0.3 to 0.0.4.
Commits
GitHub
Looks like discourse-fonts is up-to-date now, so this is no longer needed.
