Build(deps): Bump discourse-fonts from 0.0.4 to 0.0.5 (PR #10828)
Bumps discourse-fonts from 0.0.4 to 0.0.5.
Commits
GitHub
OK, I won’t notify you again about this release, but will get in touch when a new version is available. If you’d rather skip all updates until the next major or minor version, let me know by commenting @dependabot ignore this major version or @dependabot ignore this minor version.
If you change your mind, just re-open this PR and I’ll resolve any conflicts on it.
